Hunter51 Posted July 24, 2020 Share Posted July 24, 2020 Is there a way to do a cedar lintel above your windows? I am not having any luck. I am going to attach a picture of a house to show what I am trying to achieve. Any help on this would be greatly appreciated. I am still fairly new to Chief and I am trying to learn as much as I can. Link to comment Share on other sites More sharing options...
robdyck Posted July 24, 2020 Share Posted July 24, 2020 Yes, in the window specification dialog, Lintels. You can add the molding there. Link to comment Share on other sites More sharing options...
Hunter51 Posted July 24, 2020 Author Share Posted July 24, 2020 Thank you robdyck. I was able to change that but how can I get the same color/material as your for it. I can type in the dimensions like your but when I try to change that to anything other than white it changes around my entire window. Link to comment Share on other sites More sharing options...
Hunter51 Posted July 24, 2020 Author Share Posted July 24, 2020 I found it! I appreciate your help. 1 Link to comment Share on other sites More sharing options...
robdyck Posted July 24, 2020 Share Posted July 24, 2020 27 minutes ago, Hunter51 said: I found it! I appreciate your help. Great! As you've no doubt figured out, in order to spec. different trim materials, you need to specify an actual molding for the casing, lintel, & sill (as needed). Link to comment Share on other sites More sharing options...
CFaasDFCo Posted Thursday at 11:05 PM Share Posted Thursday at 11:05 PM On 7/24/2020 at 1:42 PM, Hunter51 said: I found it! I appreciate your help. Can you please share what you did? Link to comment Share on other sites More sharing options...
DBCooper Posted Thursday at 11:38 PM Share Posted Thursday at 11:38 PM If you want to have a different material for your lintel than the rest of your window/door trim, you need to pick a custom molding: Link to comment Share on other sites More sharing options...
