manual dimensions
K-Lynn
Is there a way to dimension by clicking two points and then show the dimension of the x or y-axis? If I use point to point and do this I get an angled dimension. Manual dimensions give me so much info I end up changing so much. Trying to figure out how to simplify dimensioning the interior framing of a house.
Thanks
MacBook Pro, X12
If you end up with an angled dimension and you want it to be orthogonal, and you don't want to muck around with dimension settings you can always use the Make Parallel tool and click on an object that is drawn orthogonal.
