Thad58 Posted July 4, 2020 Share Posted July 4, 2020 I want to change my default color to a Benjamin Moore color 2111-70. I down loaded it to my library but can not change the default color to it. Link to comment Share on other sites More sharing options...
joey_martin Posted July 4, 2020 Share Posted July 4, 2020 Change it in the wall layer definitions Link to comment Share on other sites More sharing options...
Thad58 Posted July 4, 2020 Author Share Posted July 4, 2020 It will not let you open the library Link to comment Share on other sites More sharing options...
joey_martin Posted July 4, 2020 Share Posted July 4, 2020 I opened my interior wall. Selected the interior wall layer. Clicked on material. Opened the library. Link to comment Share on other sites More sharing options...
Thad58 Posted July 4, 2020 Author Share Posted July 4, 2020 I did that but it changes the material name to the color not the pattern. Or do i just rename the mater Drywall and the color number Link to comment Share on other sites More sharing options...
joey_martin Posted July 4, 2020 Share Posted July 4, 2020 Colors don't have patterns. Link to comment Share on other sites More sharing options...
Thad58 Posted July 5, 2020 Author Share Posted July 5, 2020 But you cant grab a library color for the drywall. OK so Chief just responded and said that was a difficult task. I will let you know. I set up a meeting Link to comment Share on other sites More sharing options...
Thad58 Posted July 5, 2020 Author Share Posted July 5, 2020 Got it. That is a lot of work of steps. Thanks I am going to change my template. Link to comment Share on other sites More sharing options...
Kbird1 Posted July 5, 2020 Share Posted July 5, 2020 15 hours ago, Thad58 said: But you cant grab a library color for the drywall. OK so Chief just responded and said that was a difficult task. I will let you know. I set up a meeting For colors Chief doesn't let you apply easily like this you can just use the BM RGB numbers ( or Hex on Mac too) from their Website ( or any manufacturer eg SW instead) and put them into the Color Box manually or even color pick them from a wall you already changed manually to the desired color within Chief. Then save it to your Library for later use.... This is a website that has this info too .....they are selling paint but the info needed is there too....https://encycolorpedia.com/e7e5e0 Link to comment Share on other sites More sharing options...
