RJBPILOT Posted July 3, 2020 Share Posted July 3, 2020 I have trim framing to soffits on, but have these still showing. Any tips how to remove them? GILBERT_CABIN.plan Link to comment Share on other sites More sharing options...
SNestor Posted July 3, 2020 Share Posted July 3, 2020 You need to give us a bit more info...like post the plan or at least a small sample plan. And...you might take a screen clip of the roof dialogue box so we can see some of the settings for this roof. Thanks! Link to comment Share on other sites More sharing options...
RJBPILOT Posted July 3, 2020 Author Share Posted July 3, 2020 Thanks Steve Link to comment Share on other sites More sharing options...
Kbird1 Posted July 3, 2020 Share Posted July 3, 2020 It appears to be a bug associated with the Eave Plumb / Straight Fascia Option , turn auto roof framing back on and switch the option with Edit All Roof planes and they go away. M. Link to comment Share on other sites More sharing options...
RJBPILOT Posted July 3, 2020 Author Share Posted July 3, 2020 Thanks Link to comment Share on other sites More sharing options...
Kbird1 Posted July 3, 2020 Share Posted July 3, 2020 if others concur please send it into Tech Support so they can have a look at it and get it added to the list... Make the sub fascias 9.25", same as the rafter and it works fine..... with either option.....( make fascia 11.25" too) M. Link to comment Share on other sites More sharing options...
RJBPILOT Posted July 3, 2020 Author Share Posted July 3, 2020 making the sub bigger messes up the thickness of the soffit........ I did the edit all with no good result. I did a work around by pulling back the rafters and sistering 2 x 6's onto the rafter and extending them.... Link to comment Share on other sites More sharing options...
Kbird1 Posted July 3, 2020 Share Posted July 3, 2020 On 7/3/2020 at 3:42 PM, RJBPILOT said: I did the edit all with no good result. Expand You need to change the Plumb/ Straight Option for that , it it the straight Option causing the issue . Using a 2x6 Rafter tail should work though..... Mick. Link to comment Share on other sites More sharing options...
RJBPILOT Posted July 3, 2020 Author Share Posted July 3, 2020 yeah.... I want square cut...... I'm good with the work around but would be nice if it worked correctly..... Link to comment Share on other sites More sharing options...
Kbird1 Posted July 3, 2020 Share Posted July 3, 2020 On 7/3/2020 at 3:50 PM, RJBPILOT said: yeah.... I want square cut...... I'm good with the work around but would be nice if it worked correctly..... Expand yep understand....... if people don't report these little "bugs" then they won't get fixed ...... Link to comment Share on other sites More sharing options...
