TRIM FRAMING TO SOFFITS
RJBPILOT
You need to give us a bit more info...like post the plan or at least a small sample plan.  And...you might take a screen clip of the roof dialogue box so we can see some of the settings for this roof.  Thanks!
if others concur please send it into Tech Support so they can have a look at it  and get it added to the list...
Make the sub fascias 9.25", same as the rafter and it works fine..... with either option.....( make fascia 11.25" too)
making the sub bigger messes up the thickness of the soffit........  I did the edit all with no good result.   I did a work around by pulling back the rafters and sistering 2 x 6's onto the rafter and extending them....
You need to change the Plumb/ Straight Option for that , it it the straight Option causing the issue .
Using a 2x6 Rafter tail should work though.....
Mick.
10 minutes ago, RJBPILOT said:
yeah.... I want square cut......  I'm good with the work around but would be nice if it worked correctly.....
yep understand....... if people don't report these little "bugs" then they won't get fixed ......
