gobuildone Posted June 30, 2020 Share Posted June 30, 2020 (edited) Alvarado plan 1-Layout.pdfAlvarado plan 1-Layout.pdfAlvarado plan 1-Layout.pdfGreetings, I am trying to draw an existing house as a rough plan so I can design a 2-story room addition attached to the back. The house is a 1940's construction over a basement with 2 crawl sections on the L&R ends. A 24x36 garage has been added recently. I currently have this as a 2-story house, with a one story garage even though there is a room space inside the garage trusses... I am not attaching my addition to the garage, nor detailing it, so I don't care. I do need to detail the house second floor hallway/ room connections/ layouts. Do I need to draw the existing second floor as an attic to the first floor and pop out a dormer to make this work? Thank you, TP I'm running X8 on a Surface Pro 3 with i7 chip Alvarado plan 1-Layout.pdf Edited June 30, 2020 by gobuildone Uploading pdf Link to comment Share on other sites More sharing options...
gobuildone Posted June 30, 2020 Author Share Posted June 30, 2020 Why does my layout pdf not show here? Link to comment Share on other sites More sharing options...
gobuildone Posted June 30, 2020 Author Share Posted June 30, 2020 Alvarado plan 1-Layout.pdf Link to comment Share on other sites More sharing options...
gobuildone Posted June 30, 2020 Author Share Posted June 30, 2020 Thank you. Do you know how I should address the 2 areas noted on the layout pdf? Link to comment Share on other sites More sharing options...
Greg_NY61 Posted June 30, 2020 Share Posted June 30, 2020 Post the plan Link to comment Share on other sites More sharing options...
Kbird1 Posted July 1, 2020 Share Posted July 1, 2020 You need a second floor as noted otherwise Chief won't allow roos on the 2nd story. Build your Roof in the Gambrel Style with the IGNORE 2nd floor check box on in the Build Roof DBX Then cut holes in the Roof planes and add your Shed Dormer(s) manually. https://www.chiefarchitect.com/support/article/KB-00915/creating-a-dormer-in-a-roof-with-multiple-pitches.html Mick. Link to comment Share on other sites More sharing options...
