Search User Library only?
ACADuser
You can also setup Filters for each Library ( Blue Funnel with red + icon) --- just look carefully at the DBX and READ IT --- as it works reversed --- at least from my point of view, you hide what you don't want to see , rather than check what you do want to see...
1 minute ago, ACADuser said:
Odd that you can not filter on/off the USER CATALOG.
I thought the same , but if you filter out the other 3 catalogs completely , you are left with only the User Catalog.
Yes but no way to eliminate the user catalog. Although mine is still somewhat small.
Speaking of user catalog, when I select user catalog/ notes I have many notes & some subfolders.
It takes a long time to open due to the display of all the notes.
I wish there was a way to turn off the display for selected folders.
Group Select only the Core, Manufacturer, and Bonus catalogs in the library browser and then right click>Search Folders.  It will still respect your other filters as well.  You can use this same method to pick and choose specific folders in your User catalog too.
