MrSousa
Temporary Dimensions showing too much information
I don't recall having this many dimensions pop up when selecting a single wall. Here is a small section of the plan I am working on, but the entire plan has dimensions pop up when selecting a single wall, which makes editing the selected wall dimensions very difficult.
Is there a way to not have so much information come up with only one wall selected?
Brian Sousa
Designer
Phillips Sousa Investments
Chief Architect Premiere X12 B. 22.3.0.55x64
What you seeing are not Temporary Dimensions.
You have Manual and/or Auto Dimensions in the plan with the display turned off.
The program will only use Temporary Dimensions when there are no other dimensions available.
If I turn off Temporary Dimensions, these do not appear. If I have Automatic Dimensions on (blue), the Temporary Dimensions (grey) still appear as before.
Eric is correct I believe....
Again I think Eric is right , The Grey ones are not Temporary Dimensions they are Auto Dimensions on a Layer you have turned off , use the ALDO to open each Layerset till you find the one they are on or Simply delete all Dimensions via Edit>Delete Objects>CAD>Dimensions ( Auto and maybe Manual) there replace the Auto Dims.
All I know is that they will toggle on/off with 'T' or if I turn them on in the menu. I have decided not to use the Temporary Dimensions. I am able to use Automatic and Manual Dimensions to get what I need.
Just to clarify when you have the 'T' turned on the dimensions are not there till you select the wall correct?  If this is the case then I am pretty sure what they are telling you about the layer being turned off is the case.  Maybe turn your dimensions on and see if they look about the same location?
Basic Example:
No Manual dimensions placed at all w/ temporary dimension on:
Manual Dimensions placed and layer turned on:
Manual Dimension layer turned off:
Temporary Dimensions Turned on but the dimension layer off which shows the manual dimensions which over-ride the temporary once placed because chief thinks there is a reason you set them where you did and it is the information you want to see:
    28411
    LFDesign
    LFDesign
