a little question and a big question
Hammer7
So I have a Big question and a little question.  The little question first.  I am using the auto story pole.  The Top of Footing is referencing the top of the garage footing and not the main house footing and I can't seem to find the handle for correcting this?  The big question is why isn't there an Index in the reference manual or somewhere else?
When you select your dimension to edit, select it by clicking near one of the markers or on the actual dimension string and NOT by clicking on the extensions.  Then you can either relocate that one snap point or drag out a new marker using the diamond shaped edit handle.
