Hammer7
a little question and a big question
So I have a Big question and a little question.  The little question first.  I am using the auto story pole.  The Top of Footing is referencing the top of the garage footing and not the main house footing and I can't seem to find the handle for correcting this?  The big question is why isn't there an Index in the reference manual or somewhere else?
There is.
9 minutes ago, steve_stuart said:
I think this is what Eric meant to say
No, that's the Help system -- I was referring to the PDF version of the Reference Manual.
I assumed the Help index would be obvious -- I may be wrong.
Thank you Eric!  The strange thing is that the index does not seem to be listed in the table of contents so unless one scrolls to the bottom of the reference manual and past the last blank page.
When you select your dimension to edit, select it by clicking near one of the markers or on the actual dimension string and NOT by clicking on the extensions.  Then you can either relocate that one snap point or drag out a new marker using the diamond shaped edit handle.
    28426
    JosephIM
    JosephIM
