A hip roof installed beneath a gable roof
Motabobo
Software can probably do this automatically. If not go manual.
Specify porch room ceilings height like 12" lower, for each porch wall  specify roof / hip wall with like 3:12 pitch. For the building set gable condition 6:12. Add a cricket.
I modeled this in Premiere 12 Trial version so attaching the plan is not possible. But here is what I did:
Built similar model floor plan
Set roofs on main floor to gables where needed
Added a front porch with railings set for hip roof
Build roof
Manually lowered roof pitch on porch to 5/12
Done
Build roof
Done
I see you have HD Pro 2021 too , and as far as I know it has exactly the same Roof Tools as Premier...
Using the .plan you sent me via email, I built this simple model in HD 2021 Pro showing what I believe you are trying to accomplish...Also, I sent you the file and the explanations via email..
Hope this helps...
Regards
Build roofs at 8/12 pitch
Done
Gable cabin help.plan
