Object Eyedropper with foundation walls
bmatth1
If there are several foundation walls in a plan view, I select one wall and modify its properties - size, width, footer, etc.  Is there a way to copy these properties and paste onto the other foundation walls?  In the object eyedropper video, it uses an example of a window.  When I try this with a foundation wall, the eyedropper does not change to a spray can - does not work at all.  Using CA Premier X12
