Fergie Posted June 12, 2020 Share Posted June 12, 2020 Hello, Not sure if I'm in the correct area for this question but I am having several issues on a plan where I have an existing home adding an addition. (Plan Attached) Problem 1) The existing house foundation wall height is 85" with 2X10 floor joists. The addition's foundation is 96" wall height with 18" Floor Truss. The plan is for the main floor to match in height. That means the addition foundation will sit lower than the existing. My problem is when I click on the foundation the heights aren't doing what I need them to do so the foundation plans in elevation view don't reflect the correct heights. Pulling my hair out over here as I'm not sure what's happening. In the elevation view the additon foundation shows 9'4 3/8 which should only show 8' or 96". The existing house has the same issue. If I move a room/walls sometimes the heights are affected. Super frustrating. I'm sure it's my error but I'm stumped. Problem 2) I have a fireplace in the addition/great room where the space the fireplace sits in will only be 60" tall. In the elevation view there is a side wall that extends up, a window above the fireplace doesn't show....ugh... I've watched tutorials but it's not working as it should. The vault/ceiling plane is a bit goofy in there. Thanks in advance for any advice. Bret Waltner Addition 2020 Updated.plan Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 12, 2020 Share Posted June 12, 2020 Sorry, I forgot about the foundation walls. Foundation walls have Default Settings and they can be manually adjusted in Cross Section cameras with exactitude (I have done this numerous times working with an Engineer). DJP 1 Link to comment Share on other sites More sharing options...
Fergie Posted June 12, 2020 Author Share Posted June 12, 2020 David, Thank you so much! Huge help! Was pulling my hair out on that fireplace wall. I agree with your roof ridgeline (additional valley) comment and the reason why it is that way is that I pulled the wall to the right of the front door further forward than the existing home wall to accommodate the staircase to the attic/room above the garage. I've watched several of your videos on youtube in the past. Thank you again for your help and response. Now to see if I can get the foundation heights fixed without pulling more hair out! Bret Link to comment Share on other sites More sharing options...
Mark3D Posted June 12, 2020 Share Posted June 12, 2020 I had a try at setting foundation heights first i set the foundation defaults to suit the new work then made sure they were set to defaults in the rooms then i manualy set the existing to the different heights it always good to get the defaults correct for the main part of your building with the fire place those walls are set to railings untick railing and use shelf ceiling as david point to in video also x12 can now select doorway with no casings that is one of x12 new features Waltner Addition 2020 Updated.plan 1 Link to comment Share on other sites More sharing options...
Fergie Posted June 13, 2020 Author Share Posted June 13, 2020 Thank you Mark. I did see that the rail was checked and made it a wall shortly after David's video. I wound up rebuilding the entire foundation and seems to be working so far. Thank you for your input. Link to comment Share on other sites More sharing options...
