netilus Posted June 9, 2020 Share Posted June 9, 2020 I'm building a 8"x16" regular masonry block wall. Is it possible to have this depicted on the floor plan? In the wall Type Definitions box under fill, there is no choice for the 8x16 CMU. Thanks! Chief x9 Link to comment Share on other sites More sharing options...
robdyck Posted June 9, 2020 Share Posted June 9, 2020 5 minutes ago, netilus said: Is it possible to have this depicted on the floor plan? It is possible, but not through the wall definition. You'd need to use distribution path to distribute a CAD block of the CMU. However, this will probably not work well at the corners. Link to comment Share on other sites More sharing options...
netilus Posted June 9, 2020 Author Share Posted June 9, 2020 Could the block depiction be added through the Fill "Custom" selection via the patterns file? If added. Link to comment Share on other sites More sharing options...
robdyck Posted June 9, 2020 Share Posted June 9, 2020 36 minutes ago, netilus said: Could the block depiction be added through the Fill "Custom" selection via the patterns file? If added. Do you have a pattern for running CMU's? If not, can you make such a pattern? If you're planning to show the blocks in plan view (which you shouldn't FWIW) will you have them all correct? If not, what's the point? This has come up before, not sure if there's any simple solution yet. Link to comment Share on other sites More sharing options...
Ridge_Runner Posted June 9, 2020 Share Posted June 9, 2020 Toooooo much work for the return, in my opinion - just my 2-cents. Not sure your reasoning for wanting an accurate floorplan showing the blocks (if that is what you are after) but no mason, again my opinion, is going to necessarily follow a plan showing the individual blocks - too many variables for that to work. Just use good notes and wall styles. Link to comment Share on other sites More sharing options...
DzinEye Posted June 9, 2020 Share Posted June 9, 2020 Using 3 layers to create the CMU wall definition you can get this .... Link to comment Share on other sites More sharing options...
netilus Posted June 9, 2020 Author Share Posted June 9, 2020 Could the block depiction be added through the Fill "Custom" selection via the patterns file? If added. Something like this. Making hollow block walls - Autodesk Community - Revit Products.html Link to comment Share on other sites More sharing options...
DzinEye Posted June 9, 2020 Share Posted June 9, 2020 7 minutes ago, netilus said: Could the block depiction be added through the Fill "Custom" selection via the patterns file? No. You 'might' be able to create something that will look okay for for one perfectly located wall, but fill patterns will not magically line up with your walls...it's a repeating background pattern that shows through where you have allowed it to. Link to comment Share on other sites More sharing options...
