Jambruins Posted May 27, 2020 Share Posted May 27, 2020 When I layout my basement columns I like to put a dimension from the center of one column to the next and so on. Is there a way to get the dimension to show like the attached picture without having to pick a column and then the next column and then having to drag the dimension up to align it with the previous dimension? Link to comment Share on other sites More sharing options...
robdyck Posted May 27, 2020 Share Posted May 27, 2020 For that, I start with a single, End to End Dimension and just drag to each column center. Very easy then to add centerline markers if you wish. There's no real auto way to get columns dimensioned. Link to comment Share on other sites More sharing options...
joey_martin Posted May 28, 2020 Share Posted May 28, 2020 I use the CENTERLINE DIMENSION tool. Makes life easier. Once you hit the center of the column, it automatically changes to a centerline dim. Then just grab the handle and snap to the next post. 2 Link to comment Share on other sites More sharing options...
