Chrisdutch89 Posted May 6, 2020 Share Posted May 6, 2020 My client has asked that a specific handrail profile be placed on the drawings. When I check the folder I see the choices but when I attempt to upload one of the choices I only get the box shown in the pdf I've enclosed. Is there a way to extract the actual profile from the box? Handrail detail - 5.6.20.pdf Link to comment Share on other sites More sharing options...
robdyck Posted May 6, 2020 Share Posted May 6, 2020 6 minutes ago, Chrisdutch89 said: My client has asked that a specific handrail profile be placed on the drawings A detail drawing and specification or used in the model, for visuals? It's just a square...seems all you need to know is the dimension? There's lots of squares available for moldings, just type 'square' in the library browser and filter by type to moldings. Once you've made your selection, you can rename and resize. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted May 6, 2020 Share Posted May 6, 2020 You need to right click on the library item and "Place Molding Profile". You can do this in a CAD Detail Window. What's happening in your example pdf is that you are placing a molding line with that molding. Display it in a 3D view and you will see that you have a square molding polyline with that molding. 2 Link to comment Share on other sites More sharing options...
