RaquelPorlamar Posted April 30, 2020 Share Posted April 30, 2020 Hi everyone, I am using CA Interiors X9, and I wa nt to recreate this corner open shelf without having the highlighted divider as you can see in my CA. Any tips? I tried two separate cabinets deleting sides but it doesn't eliminate the side cabinet door frame. Thank you in advance ❤ Link to comment Share on other sites More sharing options...
MarkMc Posted April 30, 2020 Share Posted April 30, 2020 Two ways using two cabinets, make sure that auto fillers are off. Just saw you are on X9, sorry plan is in X12- attached it anyway-maybe get a trial or download the X12 viewer. One is two angle front cabinets, the other is two standard that overlap. If you need it really clean then do what Eric said and build it from parts or create a symbol. I don't remember if you can have 0" separations in x9-they are used to do what I posted. 1 Link to comment Share on other sites More sharing options...
Ridge_Runner Posted April 30, 2020 Share Posted April 30, 2020 There was a discussion of this recently on this forum. I believe that one was for a base cabinet but the principle would be the same. A search should bring it up. Maybe Mark will chine in. Oh, he just did as I was typing! 1 Link to comment Share on other sites More sharing options...
IRDesign Posted January 18, 2025 Share Posted January 18, 2025 Did this ever get resolved? I see it can be done in the rendering above, but it's never explained how. Link to comment Share on other sites More sharing options...
MarkMc Posted January 20, 2025 Share Posted January 20, 2025 On 1/17/2025 at 7:05 PM, IRDesign said: Did this ever get resolved? I see it can be done in the rendering above, but it's never explained how. Latest method I use attached. corner cab.zip 1 Link to comment Share on other sites More sharing options...
