PPRGLLC Posted April 26, 2020 Share Posted April 26, 2020 I usually print layouts on 24"x 36" paper so that is what my layout template is set up to do. A client wants to print on 11"x 17". When I change the size of the drawing sheet, it changes the paper size without adjusting the title boxes, notes, etc. Is there a way to resize the entire layout without creating a new layout template for 11" x 17" paper? Link to comment Share on other sites More sharing options...
Chopsaw Posted April 26, 2020 Share Posted April 26, 2020 Is this just for concept drawings? You could just print and use the fit to paper setting but your scale would not be anything standard. Some people have a 22" x 34" layout and print at 1/2 Scale Check Plot which just turns your 1/4" scale drawing to 1/8" Maybe you could cheat and use 12 x 18 paper ? Otherwise Yes you need to redo your title block. Link to comment Share on other sites More sharing options...
DG1949 Posted April 26, 2020 Share Posted April 26, 2020 On Page 0, select all the boxes, text, etc., and then select Transform/Replicate and Resize by a factor of .472. Should be very close to fitting on the new 11x17 sheet. Then just save as a new template. 1 Link to comment Share on other sites More sharing options...
