DOPSuppliers Posted April 24, 2020 Share Posted April 24, 2020 (edited) The OK pic is from an AS Built I did and the Problem pic is from the same, but saved as proposed plan and I can not figure out what I did that is different and why it changed. I have never seen this. OK Footer.pdfFetching info... Problem Footer.pdfFetching info... 3D.pdf Edited April 24, 2020 by DOPSuppliers Add pic Link to comment Share on other sites More sharing options...
DOPSuppliers Posted April 24, 2020 Author Share Posted April 24, 2020 Eric, I don't believe I know how to do that ... Link to comment Share on other sites More sharing options...
parkwest Posted April 24, 2020 Share Posted April 24, 2020 Just drag the image to the text box on here. Link to comment Share on other sites More sharing options...
joey_martin Posted April 24, 2020 Share Posted April 24, 2020 The front wall may have the main layer reversed or set up wrong. Look like the inside of the wall is marked as the "to foundation" layer. Or, you have an offending invisible attic wall throwing everything off. 1 Link to comment Share on other sites More sharing options...
DOPSuppliers Posted April 24, 2020 Author Share Posted April 24, 2020 Joey Martin, thanks so very much for your assistance! It wasn't one of your ideas, but while checking on those, I noticed a box checked on the structure tab that should not have been that I hadn't seen during the other "100" times I went through those details. Thanks again, Link to comment Share on other sites More sharing options...
CharlesVolz Posted April 24, 2020 Share Posted April 24, 2020 So the answer is . . . ? Rebuild foundation? Link to comment Share on other sites More sharing options...
DOPSuppliers Posted April 25, 2020 Author Share Posted April 25, 2020 Charles, I found I had somehow checked the box - Stop wall at floor below, in the structure tab of the wall specs on that particular wall only. I looked for inconsistencies numerous times without seeing that. Link to comment Share on other sites More sharing options...
