Rafter Tails
builtright3
7 minutes ago, builtright3 said:
I tried to run a roof from the top down and putting a negative pitch but it recognized the lower portion as the eaves
Yep... I tried too.  It doesn't seem to want to put rafter ends on the high side no matter what.
I may have to manually put the rafters in and turn off the rafters layer
Unless someone else has easier way another way.
Edited by builtright3
Sorry I think i was thinking of beams, and maybe if did the roof with a 0 pitch even though I wanted some slope.
Symbols may be the way to go.
Have to go out for a few hours so I will try symbols when I get back. Haven't worked with symbols in a while so I have to check the help.
A psolid may be just what you need drawn in elevation view but converting to a symbol sort of locks it if things are final.
