Sign in to follow this
DesignerPro2020
Dimensions not locating objects
Any suggestions on forcing dimensions to snap to framing objects?  I have looked at dimension defaults for the framing floor layer, selected sides.  Dimension tools are not putting 'x' to indicate located object.
Any help is appreciated.
X12 version
Here are the critical settings in the dimension default being used for that. You can locate other objects as well if need be.
image.thumb.png.378f284eade214935c8f5add6d9c794c.pngimage.thumb.png.97100d18e748a3d1f9dde643663f9d06.png
Be sure your Intersection snaps are turned on as well.
    28573
    Reef_Builders
    Reef_Builders
