Alyssa5 Posted March 18, 2020 Share Posted March 18, 2020 Hi, I have attached a couple of screenshots to best describe my problem Whenever I move the camera view, I get this sort of distort colouring on my walls? Any ideas what's causing this? Thanks Link to comment Share on other sites More sharing options...
rgardner Posted March 18, 2020 Share Posted March 18, 2020 Do you have another building in your plan? Appears you have a big shadow showing. couple of things to try if you don’t. 1.) temporarily toggle your shadows off 2.) adjust the sun to follow camera Link to comment Share on other sites More sharing options...
Alyssa5 Posted March 18, 2020 Author Share Posted March 18, 2020 6 minutes ago, rgardner said: Do you have another building in your plan? Appears you have a big shadow showing. couple of things to try if you don’t. 1.) temporarily toggle your shadows off 2.) adjust the sun to follow camera No only the one building in plan Have just tried those and it just made it darker? Link to comment Share on other sites More sharing options...
Chopsaw Posted March 18, 2020 Share Posted March 18, 2020 Wow. That almost looks like Z fighting but definitely not quite what you would typically see. Maybe check the thickness of the exterior layer of siding to make sure it is at least 1/4". Also is the building anywhere near the 0,0 point of origin ? If it is not that, it could possibly be a video card or video card driver issue. Maybe let us know what version of the software you are using an post your plan file if you can't resolve the issue. 1 Link to comment Share on other sites More sharing options...
rgardner Posted March 18, 2020 Share Posted March 18, 2020 56 minutes ago, Alyssa5 said: No only the one building in plan Have just tried those and it just made it darker? Yes looks like something is up. Best to do as chop mentioned and post a plan to confirm or rule out whether it’s a hardware issue. Link to comment Share on other sites More sharing options...
Alyssa5 Posted March 18, 2020 Author Share Posted March 18, 2020 4 hours ago, Chopsaw said: Wow. That almost looks like Z fighting but definitely not quite what you would typically see. Maybe check the thickness of the exterior layer of siding to make sure it is at least 1/4". Also is the building anywhere near the 0,0 point of origin ? If it is not that it could possibly be a video card or video card driver issue. Maybe let us know what version of the software you are using an post your plan file if you can't resolve the issue. Thanks so much for your suggestions, it was the origin it was waaayyy off 0,0 worked out how to change it closer to 0,0 and now it looks better Thanks so much 1 Link to comment Share on other sites More sharing options...
