Moving Object Origin
kwhitt
I've been importing some symbols today for my user catalog.  I've got a 3-bladed ceiling fan where the origin isn't geometrically centered.  I thought by moving the model (in the symbol DBX) so that the Y-axis was centered on the motor, this would put the plan origin in the correct place.  Not the case.  How do I go about this?  Thanks, Kevin
You need to place something extra into your cad block that centers it up.  A visible solution I have used that is handy would be to place a dashed cad line to mark the outer circumference of the rotation path.  Other methods would be a blank or white line or marker or an empty text box works well.
Expand
Chop - does that mean I have to import this new symbol from the app it was created in?  I tried to select the existing symbol AND the circular CAD line, but I no longer have the option to convert to a symbol.  How is this done in CA or is it necessary to import again with the circle as part of the geometry?
Sorry one other thing I forgot is that cad blocks for symbols do not respect line styles.  So don't bother trying a blank style or in my example a dashed line style.   I did that by using distributed line segments.
You take the existing chief generated block from CAD Block Management ( usually although you can start from scratch ) and then insert it and edit as you like then re block and apply that new 2D cad block to the symbol in question.
Expand
The reason I started using the empty text box is that its the only one that makes everything disappear.  I used to use points and zero length lines but ultimately all those other methods I used showed up as dots in one view or another (which was really only a minor problem but an annoyance nonetheless).  The text boxes are truly invisible.
