Still consider myself somewhat of a beginner when it comes to this software and my ability with elevations is terrible. Our house plans are finished on a flat level surface, however our actual property is anything but. I'd like to add in our property elevations and grading so we can get a better idea of what it will look like but I struggle to even do simple landscaping work in this software. Is there anyone out there who feels they have simplified the instructions, or could help me through this?
I think the biggest stumbling block that people seem to have with Chief Terrain is that it requires real data.  If there is no overlapping data and the terrain is something you could walk on it should work out ok.
Mark3D did a video not long ago that has some of the basics.
My tips are:
Don't use Elevation Points - use Elevation Lines/Splines.
Use Elevation Regions as much as possible.
Don't overlap elevation data.
Don't use Retaining Walls - use Terrain Breaks and normal walls placed after.
Use Elevation Data instead of the Terrain Modifiers.
Don't use Automatic Subfloor Height Above Terrain.
Tile a 3D view with the terrain plan as you work so you can see the immediate results of your input.
To add to and expand upon what Glenn and Chop have already said...
-The “real data” (as Chop called it) is key.  You need to actually provide useful information to Chief.  Every bit of this initial responsibility is 100% on us...the designers.  You will always struggle if you haven’t taken the proper steps to gather and wrap your head around the ACTUAL elevation data.  If you don’t have it you can’t give it to Chief, and if you don’t understand it, you’ll never be able to troubleshoot it.
-Keep it simple.  You need to give Chief proper and accurate data to work with, and you need to provide enough data to get your desired end, but don’t input more than you really need.  If you have a flat spot at the top of the lot that has a perfectly flat slope to a lower flat spot at the back of the lot, use 2 Elevation Regions (which by the way are essentially just closed elevation polylines with the optional ability to make the inside flat) and don’t place any additional elevation contours.  The extra elevation lines would just be a waste of time and add extra data to deal with...as well as the related increased potential for problems.
-I have to somewhat disagree with Glenn’s second to last statement.  My advice would be to UNDERSTAND the difference between Elevation Data and the Terrain Modifiers.  Always DEFINE your terrain FIRST with elevation data.  If necessary you can then use Terrain Modifiers.  Just remember the terrain modifiers will always do what they do based on the underlying terrain definition.  They don’t define anything.  They only tweak it.   It’s like sending someone to make a flat spot for a 2ft. diameter area at some random spot on your lot without bringing in any fill, without taking any fill out, and without disturbing anything outside the immediate vicinity.  The overall depth on one side, drop on the other, and vertical elevation will all depend  ENTIRELY on the height and contours of the terrain on that specific area of the lot.
-Don’t get hung up on the vertical location of your house as you’re tweaking the terrain.  It’s easy to move the house/terrain up/down at any time.  Instead, keep your focus on the overall contours of the land.  You shape your terrain and you change the Subfloor Height as it relates to that terrain.  Just don’t try to change your elevation data to fit to the house.  You’ll just be chasing your tail.
At the end of the day, what I ultimately found is that terrains are FAR easier than most people think. You just have to go at them calmly and methodically, making sure you think through what you are actually telling chief.
    27855
    kfilipova
    kfilipova
  • Similar Content
    • By Designer100
      I have designed a pergola and a deck. I cannot get the terrian to show right. It needs to be zero of level at back of deck by pool deck and slowly slope down to a bayou. it needs to be 36" to grade at edge of outer deck Then a stair going down to the end of stair which is around 5 fr lower that top of deck. I have not did much terrian and would appreciate your help. This is just a remodeling and adding a deck from the pool.
      Thank  you,
      Nerwell
      newell.cheatheam@gmail.com
      Pergola_.plan
      11X17.layout
    • By KahlilHenley
      Chief Architect has been a blessing to me in the last year that I have been utilizing the software. However, I work in the United States Virgin Islands St. Thomas,  where there are seldom flat land to build on. Therefore, there is always a slope in the land and I am having a hard time landscaping. Are there any techniques or tips anyone can offer.
    • By tracer
      having problems with the terrain not going against terrain wall. any suggestions?
      TUTTLE TERRAIN.pdf
      TUTTLE TERRAIN 2.pdf
      MAYNARD_TUTTLE_11_21.17.plan
    • By WhistlerBuilder
      Hi everyone,
      I am stuck on a tricky terrain issue. I am designing a multi family building site that has some relatively simple grading required for the parking lot and pedestrian access which chief cannot seem to accurately process. Perhaps I am missing a trick? I have uploaded the relevant portion of my plan so you can take a look.
      Basically I have a pedestrian access "sidewalk" coming on the property at a higher elevation, and a driveway leading to a parking lot at a lower elevation. The driveway and parking lot all have carefully calculated grades leading to the elevation I have set as top of parking slab (2159.00 ft). After days of messing with the retaining walls and terrain breaks I finally got the parking lot to work. Now the problem is that chief cannot seem to handle terrain topographic lines intersecting the top of a retaining wall / terrain break without creating absolutely batshit crazy peaks and valleys everywhere. Since the site requires that I have a sidewalk pedestrian access at the top of one of these retaining walls with a maximum slope of 2%, these crazy variations are screwing up my plan. I cannot seem to get rid of them except with flat terrain areas, which of course screw up the pedestrian access elevations. I can't just cheat and do stairs because this building needs to be handicap accessible. Chief cannot do terrain area's with a slope... something they should absolutely add!!!!!
      How do I fix this problem?
      I would really appreciate some help here as I have spent the last few days really struggling with the terrain features of chief and I am at my wits end trying to figure out this issue.
      Help_Plan.plan
    • By CBRF23
      Does anyone know how to make a driveway that runs up a sloping lot at an angle.  Seems like it should be simple, but I'm racking my brain here and have come up empty with multiple attempts.  You can see what I'm going for in the images below.  The driveway feature just paints a driveway on top of the existing terrain topography, and I can't figure out how to create a slab or a terrain feature that slopes continuously the way you would expect.
      I'm using chief X9, plan file attached.
      Plan.zip
