WoodlandDesign Posted March 9, 2020 Share Posted March 9, 2020 I reviewed this older posting: http://www.chieftalk.com/showthread.php?65927-varying-lap-siding-reveal and was able to successfully download the pattern created. What I don't understand is how one transfers that pattern to the texture file for 3D viewing? I'm hoping it's easier to do this now as the posting dates back to 2014? Here's the elevation view with the intended siding pattern: Now to just get the material to follow. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 10, 2020 Share Posted March 10, 2020 Texture and Pattern are 2 entirely different things. You’ll need to find or create a seamless texture. Link to comment Share on other sites More sharing options...
Kbird1 Posted March 10, 2020 Share Posted March 10, 2020 7 hours ago, WoodlandDesign said: I reviewed this older posting: http://www.chieftalk.com/showthread.php?65927-varying-lap-siding-reveal and was able to successfully download the pattern created. What I don't understand is how one transfers that pattern to the texture file for 3D viewing? I'm hoping it's easier to do this now as the posting dates back to 2014? There is a Material in the other File in that Thread but as Eric Pointed out these days you can likely make a better one fairly easily, then use the Pattern from the Thread too for vector views. Patterns = Vector Views Textures = 3D Views Like Standard. ( seamless Textures are best ) M. Link to comment Share on other sites More sharing options...
WoodlandDesign Posted March 10, 2020 Author Share Posted March 10, 2020 Thanks all. What basic image editor program would you recommend? I think the only one I have is Paint but it's probably 10 years old. Link to comment Share on other sites More sharing options...
Kbird1 Posted March 10, 2020 Share Posted March 10, 2020 23 minutes ago, WoodlandDesign said: Thanks all. What basic image editor program would you recommend? I think the only one I have is Paint but it's probably 10 years old. Paint works just fine if you are familiar with it ? there is also the newer Paint 3D on most PCs. Paint.net is free if downloaded from their Site direct , (not the M$ Store too) https://www.getpaint.net/download.html a better download link......................https://www.dotpdn.com/downloads/pdn.html https://www.getpaint.net/doc/latest/index.html https://forums.getpaint.net/forum/18-tutorials-publishing-only/ And there is the longtime Free Standby GIMP too. M Link to comment Share on other sites More sharing options...
WoodlandDesign Posted March 10, 2020 Author Share Posted March 10, 2020 Thanks Mick. No. I'm not familiar with Paint. I don't think I ever used it. I'll try to experiment with the suggestions you forwarded. -DG Link to comment Share on other sites More sharing options...
Kbird1 Posted March 10, 2020 Share Posted March 10, 2020 5 minutes ago, WoodlandDesign said: Thanks Mick. No. I'm not familiar with Paint. I don't think I ever used it. I'll try to experiment with the suggestions you forwarded. -DG Paint will work , it is very "basic" with no frills is all...... I used it in this Tip to make a new Tile Material for example..... https://chieftalk.chiefarchitect.com/topic/24813-how-to-make-a-screen-grab-of-a-tile-into-a-tile-material-in-chief / Link to comment Share on other sites More sharing options...
WoodlandDesign Posted March 10, 2020 Author Share Posted March 10, 2020 Perfect. A tutorial will be helpful! Link to comment Share on other sites More sharing options...
