creatrix Posted February 8, 2020 Share Posted February 8, 2020 Using CA Premier X11on iMac Mojave Would someone kindly tell me what I have done to make my menu bar a single line rather than the stacked double line? Link to comment Share on other sites More sharing options...
Signatures Posted February 8, 2020 Share Posted February 8, 2020 Welcome It's helpful to know what software you are using as it changes from version to version. It helps others to have this info in your signature so it's always available. Please see this topic for a signature how to. https://chieftalk.chiefarchitect.com/topic/18908-signature-here-at-chief-talk 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted February 8, 2020 Share Posted February 8, 2020 Sounds like you my have been using the Extended Tool Configuration. Right Click on empty section of tool bar and > Toolbar Configurations > Extended Tool Configuration. Link to comment Share on other sites More sharing options...
creatrix Posted February 8, 2020 Author Share Posted February 8, 2020 Oh Chopsaw, I'll try that and thank you! Trying to set up my Signature. Link to comment Share on other sites More sharing options...
creatrix Posted February 8, 2020 Author Share Posted February 8, 2020 No I'm using the Kitchen and Bath config. so not extended. Link to comment Share on other sites More sharing options...
Chopsaw Posted February 8, 2020 Share Posted February 8, 2020 Sorry I did not look at your screen shots as carefully as I should have. The toolbars are built in sections that can be rearranged. You can select a section where the four little dots are and move it to dock below the other tools or even on the side bars of your screen. Possibly that happened by accident or corruption, but can be corrected. Link to comment Share on other sites More sharing options...
creatrix Posted February 8, 2020 Author Share Posted February 8, 2020 Hallelujah! What awesome help you have given me — I am truly grateful! Have a lovely evening! Link to comment Share on other sites More sharing options...
Kbird1 Posted February 8, 2020 Share Posted February 8, 2020 You can also in Preferences Use the Reset Options >Reset Toolbars command. If you Lock your toolbars this tends not to happen accidently too. M Link to comment Share on other sites More sharing options...
