TopagnaOverlook Posted January 25, 2020 Share Posted January 25, 2020 When I use AutoStairwell, or position railings manually on the floor above, the room with the railings changes to a concrete floor. With either AutoStairwell, or manually placing railings with open below, there is concrete overhang in the opening. Plan is attached. Can someone point me in the right direction? House2.plan Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 25, 2020 Share Posted January 25, 2020 You just seem to have a faulty room definition. Check out the Structural panel for that room and look at the settings in there. Specifically, check the ceiling height and decide whether that room should really be set to have a monolithic slab or not. Link to comment Share on other sites More sharing options...
TopagnaOverlook Posted January 26, 2020 Author Share Posted January 26, 2020 Thanks Michael, I got the structure of that room back to normal. But when I put the railings/open to below room in, the surrounding room structure changed from "Ceiling below" to "SWT below". I'll see if I can re-create that behavior with a simple two-floor plan. Link to comment Share on other sites More sharing options...
rgardner Posted January 26, 2020 Share Posted January 26, 2020 5 minutes ago, TopagnaOverlook said: Thanks Michael, I got the structure of that room back to normal. But when I put the railings/open to below room in, the surrounding room structure changed from "Ceiling below" to "SWT below". I'll see if I can re-create that behavior with a simple two-floor plan. Try saving before you putting in the room also you could try the stair open above tool when you select the stair set on the lower floor it should show up and create an auto stairwell. You can adjust the walls after that point. May help? Link to comment Share on other sites More sharing options...
TopagnaOverlook Posted January 26, 2020 Author Share Posted January 26, 2020 Thanks Ryan, I previously tried the open above tool and it shows the same behavior. Seems to show the same results as making the stairwell manually. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 26, 2020 Share Posted January 26, 2020 9 minutes ago, solver said: And ... Good catch Eric. Link to comment Share on other sites More sharing options...
TopagnaOverlook Posted January 26, 2020 Author Share Posted January 26, 2020 Thanks Eric, I know I didn't change those default settings intentionally. I can only assume that during some experimentation with railings I hit the "set as default button" by mistake. I'll be carefully checking defaults the next time I encounter unexpected behavior. Makes me want to move that "set as default" button somewhere I'm less likely to hit it. Is "Edit Area, copy, delete, paste/hold" to restore the default structure on the entire floor? I'm surprised that the paste/hold doesn't bring the structure of the copied floor on the clipboard with it. Two great tips! Link to comment Share on other sites More sharing options...
