Auto Story Pole Dimensions Issue
wjmdes
Not sure if this was an issue in X11, but in X12, I added "FIELD VERIFY" to Trailing Text under Segments and it also added "FIELD VERIFY" into the extension next to the elevation.  Fortunately, in this case, that is fine, but maybe an issue in the future.
The framer does not care about ceiling height but instead top of stud wall.
Top of stud wall (plate) and rough ceiling are the same thing.  On this particular project, it is a remodel, so the framer needs to match existing elevations.
2 minutes ago, wjmdes said:
Top of stud and rough ceiling are the same thing.
I think you mean Top of Wall Plate and Rough Ceiling are the same thing...   Typically  that is probable right, but I usually use Top of Plate as well
I am also a structural/civil engineer and I have always associated plate height with structural steel.  But as long as the guy swinging the hammer understands...
Depends on construction I usually use strapping theen apply the ceiling makes for a more uniform ceiling.
4 hours ago, raltd9245 said:
Depends on construction I usually use strapping then apply the ceiling makes for a more uniform ceiling.
Yes, in Chief that would be the Finished Ceiling Height though , not the Rough Ceiling Height which would normally be the Wall Height or Top Plates.
    32919
    scottdanville
    scottdanville
  • Similar Content
    • By jbur91
      Using Chief X12 and have a question about rounding.
      Is there a way to make dimensions round to the nearest fraction? Using the manual dimensioning tools, the program is rounding inconsistently. For example, I have my current dimension defaults set to show fractions to the nearest 1/2". However, it won't round to the nearest 1/2", it will only round down. One measurement in particular is 10'-4.94", and it's showing up on the floor plan as 10'-4 1/2" instead of 10'-5" like I want it to. This is causing exterior dimensions to appear inconsistent and is overall a huge headache for me.
      Is there some setting I'm not aware of that is preventing the dimensions from rounding up when I need them to?
      Thanks,
      Jack
    • By AndrewSopher
      Hello,
      I have been working on a stepped foundation and was wondering why in the cross section for the foundation it does not display the entire wall length? It seems to extend only until the perpendicular wall intersects it. I was wondering if there is a way to change this and if not what are the easiest ways around this or to accurately measure it in the floor plan view. I attached an image (in this case there is a 4'' gap on the left side and a 3'' gap on the right side of the screenshot). Thanks.
    • By Designers_Edge
      I have had this issue for a couple of years and just lived with it.  I do have an iMac with the Apple mouse.  Often when I do long end-to-end dimensions the lines are not straight or drawing a CAD object, they are off.  I have my "angles" checked so that I am not drawing an off angle item.  I have gone into Chief preferences and see nothing there and have also gone into the System Preferences on my computer to see if there are any controls for the mouse.
      I never had this problem before.  It used to be, that I didn't have to worry about actually drawing a straight line, as Chief seemed to make sure the intended straight line was drawn that way.
      I put an example --this is a CAD line that I attempted to draw and I truly meant to draw it straight.  What am I missing??
    • By Designer100
      Pole dimesnons on Elevation 3 left is putting wrong ceiling ht at 102" (or 8.5") surpose to be 9'. cannot seem to change it in defaults.
      going to levels 1st floor defaults , it shows correct at 108 in. But then under pole dimensions it shows 8 ft 5 in.  I would appreciate any help.
      Interactve Copiers Unlimited Building.plan
    • By MarkMc
      I received a couple of question from folks at and after yesterdays GTM I'm attaching a plan and a layout in a zip file. Consider this something for forensic examination-to use to figure out how you want ot go about things. There are very likely mistakes, I'm certain that some of the label macros need work and in the course of putting this together some unwanted ones may have dropped in from the library..
      There was a request at the meeting for annosets. I agree with Perry and Scott that you need to put together what works for you but this may help get you going. The annosets here are a recent update to mine and may have mistakes yet. Started with something, a year or so later updated it, learned some more, fudged it as I went, now going working on a new and improved revised set. No you do NOT need to change annosets with every release. Yes you can use the same annosets for multiple templates (reference manual). OR you can use different ones. It's a good idea to export them somewhere (like the CA data file) with a date associated for when you muck them up or need to go back or want them somewhere else. I keep a second set that is less used for new construction that is different than my everyday remodel set. Just cuts down on the clutter.
      Label macros included- the principal I'm working with is to use one macro while I work so I know what is going on, then to change all the cabinets on the primary layers to have another macro that works for ordering nomenclature (3 inch increments for example) To get any of the macros out you open the macro management dbx pick it and export- then do the reverse in another plan and import (HIT F1)
      There was a question about the molding warehouse- included some in one room with a note. Don't forget to play with the new drag a profile from the library feature.
      Countertops-no chief will not automatically label finished edges- see the plan, keep some text int there and copy and paste. (maybe someone from the dark side can write a macro for that but I'm not going there.) A few ways to get millwork and other things into a schedule- included one arch block turned sideways to show the problem from using them. couple of odd symbols thingies for the schedules. Included-an architectural block with a wood hood and a blower insert inside it. The blower insert is currently set so you can't really resize it without going into the symnbol DBX and changing things (look in the reference manual and play with it -best way to learn) You can use this to see if the blower you want will fit in the hood the client wants. Glass house view, cross section slider, backclipped elevations. Odds and ends-if you have not seen Scott Harris method of globally changing kitchen cabinets you should check it out. Basically he keeps a couple of cabinets on the side in different door/color/construction. Then picks one and sets as default  (one reason I ONLY use cabinets that respect the defaults even though some things don't AND naturally changing from overlay to inset requires some heavy redesign) There was a mention that 2020 will underline a label if you alter the size of a cabinet from the default. Chief won't. Thing is that 2020 will also underline the label if you add an accessory or a modification to the cabinet so it is NOT saving you from yourself (unless you do those last) File and layout attached, neither is complete, but worth fooling with I think.
