gelbuilding Posted January 20, 2020 Share Posted January 20, 2020 (edited) I need to make a pattern in herringbone. How do I change the board size to 780 long x 156 wide? The length size I cannot change as it is greyed out, Thanks Edited January 20, 2020 by gelbuilding spelling Link to comment Share on other sites More sharing options...
gelbuilding Posted January 20, 2020 Author Share Posted January 20, 2020 Timber flooring and the size is specified. Link to comment Share on other sites More sharing options...
mattyt12 Posted January 21, 2020 Share Posted January 21, 2020 Not quite an easy solution and never used personally but you could try hatchkit, or it is possible to manipulate patterns in notepad albeit more complicated. Both covered off in the thread below. It would be nice to control the height and width of the pattern as you can with the Grid patterns though Link to comment Share on other sites More sharing options...
Kbird1 Posted January 21, 2020 Share Posted January 21, 2020 On 1/20/2020 at 2:36 PM, gelbuilding said: I need to make a pattern in herringbone. How do I change the board size to 780 long x 156 wide? The length size I cannot change as it is greyed out, Thanks Hi G. I recently found this website for making Patterns ......................https://pattycake.io/ but here is a 6x30" which I think approximates the size you need, use File>Import>Pattern to bring it into Chief. Use the Rotate Angle on the pattern Tab if you want diagonal Herringbone (45°) as soon below 6x30 Herringbone.pat 2 Link to comment Share on other sites More sharing options...
gelbuilding Posted January 21, 2020 Author Share Posted January 21, 2020 Great, Thanks Mick Link to comment Share on other sites More sharing options...
mattyt12 Posted January 21, 2020 Share Posted January 21, 2020 nice find Mick Brick1.pat Link to comment Share on other sites More sharing options...
