winterdd Posted January 19, 2020 Share Posted January 19, 2020 so, my new project is a one story home with flat ceilings throughout and a two car garage. i have a couple questions. 1) the owners want a dormer centered on the house but want it functional to allow natural light into the living room. does the attic have to be changed to a "room" to allow this? if so, can i create a second floor with like 3-6" ceiling height just to get it labeled as a room? im sure it won't be built like this in real life, correct? 2) bonus room above the garage. will not have a flat ceiling. will be sheet rocked to followed the rafters (vaulted). again, does this space above the garage which chief considers an attic need to be changed to a room with a minimal ceiling height to allow the stairs finding it as a second floor? thanks! Link to comment Share on other sites More sharing options...
winterdd Posted January 19, 2020 Author Share Posted January 19, 2020 i figured out something better for my situation. build a second floor. draw your dormer walls manually. set to "open below". boom, throw your roof plane on the dormer and some windows and it works perfect. Link to comment Share on other sites More sharing options...
dshall Posted January 19, 2020 Share Posted January 19, 2020 11 hours ago, ChiefUserBigRob said: i figured out something better for my situation. build a second floor. draw your dormer walls manually. set to "open below". boom, throw your roof plane on the dormer and some windows and it works perfect. I Agee, build dormer manually ON THE FLOOR ABOVE, check roof cuts wall at bottom, put hole in roof.... I do not think it is necessary to create a room. I did countless videos years ago trying to figure this out. Link to comment Share on other sites More sharing options...
rgardner Posted January 19, 2020 Share Posted January 19, 2020 2 hours ago, dshall said: I did countless videos years ago trying to figure this out. Haha I just watched one of your videos about this last night! Always trying to improve on my dormers as there always seems to be little “glitches” that I am obviously telling it incorrectly how to model it. Not usually with the walls but with the ceiling above when I try to get it to be open to below on the edges. Just extra fiddling around to get it to look good in interior shots and renderings. Link to comment Share on other sites More sharing options...
