LarryDee Posted January 17, 2020 Share Posted January 17, 2020 Most of plans created in CA 10 are opened by CA 11, then can save into new CA 11 program. I have a CA 10 plan that will not open in CA 11. When opening in CA 11, info box opens and green progress line starts, but then ends short before completing, and a blue processing circle seems to go on forever without opening the plan. I need to edit plan and then save into CA 11. Link to comment Share on other sites More sharing options...
Chopsaw Posted January 17, 2020 Share Posted January 17, 2020 Any issues opening and working in X10 ? Link to comment Share on other sites More sharing options...
LarryDee Posted January 17, 2020 Author Share Posted January 17, 2020 No, but other related plans to design project were created in 10 and then saved into 11. Need to get last plan converted, but just goes into a loop and won't open. Link to comment Share on other sites More sharing options...
Chopsaw Posted January 17, 2020 Share Posted January 17, 2020 Maybe run Plan Check in X10 and see if there are any potential issues before importing to X11. Maybe check with tech support in the morning ? If your SSA is up to date get the beta version of X12 as soon as it is released and try that in case there is a bug with X11 that has been worked out. Anything that you recall being different about that particular plan file ? If you are out of ideas you can always post the plan file and maybe it will load on someone else's hardware configuration. Link to comment Share on other sites More sharing options...
LarryDee Posted January 17, 2020 Author Share Posted January 17, 2020 I'll give it all a try! Thank you for your time and advice. Link to comment Share on other sites More sharing options...
lbuttery Posted January 17, 2020 Share Posted January 17, 2020 BTW: best practice is to use X10 and X11 names otherwise there is confusion with the much older Chief 10 and 11 (which really didn't exist back then) Lew Link to comment Share on other sites More sharing options...
LarryDee Posted January 20, 2020 Author Share Posted January 20, 2020 Thank you Lew, you are certainly correct! Please excuse my brevity oversight. Link to comment Share on other sites More sharing options...
Chopsaw Posted January 20, 2020 Share Posted January 20, 2020 On 1/17/2020 at 1:03 AM, LarryDee said: I'll give it all a try! Thank you for your time and advice. Any luck with the file Larry ? Link to comment Share on other sites More sharing options...
