Custom Tiled back-splash Brick Pattern
DaveBox
Hi all.
I am attempting to lay out wall tile in a Brick third pattern in X10.
I have captured the texture (new material 45) from a screen and applied it to the top custom back splash.
I have then copied the plan material and sized the texture (24x12) and the custom pattern.
It then renders in stacked tile pattern.
What am I doing wrong?
Plan attached
ThirdBrick Tile pattern.plan
27 minutes ago, DaveBox said:
Plan attached
In order for us to see your material you need to include the texture source file. Common ways to do this is choose File/Backup Entire Plan/ with the active plan opened.
I'll show you a 2 row brick pattern to illustrate the solution:
There is no offset tool in CA, you must create the offset in your texture
* EDIT  I moved the full text of the reply to the TIPS sections for Others here
https://chieftalk.chiefarchitect.com/topic/24813-how-to-make-a-screen-grab-of-a-tile-into-a-tile-material-in-chief /
Pattern:
12 x 24 1-3rd Offset.pat
Material for Library '''Import" as usual....
MHD_1-3rd 12 x124 Stacked Brown Tile.calibz                FOR X11 OR UP ONLY SORRY ,
        use Pattern and Texture above to make your own material if needed.
22 minutes ago, DaveBox said:
So the custom pattern does not array the tiles?
1.) No , it is simply a line drawing for Vector Views.......
2.) No , but it's a whole lot easier with the free Excel File.....  see above.... I did it for you and made a new Chief material ..... :)
    32890
    paulPHB
    paulPHB
