SNestor Posted January 6, 2020 Share Posted January 6, 2020 OK...sorry for not asking this before. Can you use a "polyline" with a fill (such as shingles) and then reference the "fill pattern" somehow in a reference set? I ask because I haven't figured out how... Thanks. Below in the pictures I have drawn the polyline with the shake fill on Level 1...and I'm trying to Reference on Level 2...the cad polyline appears...but, no "fill pattern". Is the "fill" on a unique layer? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 6, 2020 Share Posted January 6, 2020 See if this helps you at all... Link to comment Share on other sites More sharing options...
Dermot Posted January 6, 2020 Share Posted January 6, 2020 Michael's post might be more complicated than you need. Try just turning on the "Details" option in the reference display. More information about the reference display settings can be found in my post here: Link to comment Share on other sites More sharing options...
SNestor Posted January 6, 2020 Author Share Posted January 6, 2020 4 minutes ago, Dermot said: Michael's post might be more complicated than you need. Try just turning on the "Details" option in the reference display. More information about the reference display settings can be found in my post here: Darn that was easy...thank you! Very much appreciate the quick response. I saw both of these those posts when they were posted,..but, it's been a while since I have messed with "REF SETS" and I just plumb forgot what I needed to do. Link to comment Share on other sites More sharing options...
SNestor Posted January 6, 2020 Author Share Posted January 6, 2020 20 minutes ago, Alaskan_Son said: See if this helps you at all... Thanks Micheal. I saw the current temps in Alaska....brrrr....stay warm! Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 6, 2020 Share Posted January 6, 2020 15 minutes ago, SNestor said: Thanks Micheal. I saw the current temps in Alaska....brrrr....stay warm! Thanks. It’s warmed up to about 17 below (F) where I live. And Dermot is right, my suggestion is probably more than you need. I read more into what you were asking them what was really there. 1 Link to comment Share on other sites More sharing options...
