Rotate portion of a floor plan
djhplanning
Am I completely missing something, or how do you go about rotating a portion of a floor plan around a specific point?  I currently have a floor plan with a potion extending at a 45 degree.  I want to rotate that 45 degree portion to 90 degrees instead.  After selecting everything that I want to rotate, I've found a tool called 'rotate/resize about current point' but don't seam to get this tool to do anything at all.  I've also tried using 'transform/replicate object' tool but rotate is not an option here as it is grayed out and I can't select it.  HELP!
This is not a tool as such, it is a setting.
ie, you can rotate objects about the current point, object centre or absolute point.
So, if you want to rotate around a point, you have to place a point first, and then rotate.
