jpdesign Posted October 30, 2019 Share Posted October 30, 2019 Hello, I have problem to use "lower wall type". This "lower wall type" unchecked. As circled in red, partial of wall under roof is still exterior wall. When check "lower wall type" for that wall, the wall portion under the roof is fixed but the half of windows disappear. How to fix this problem? Thanks, Josh Link to comment Share on other sites More sharing options...
Kbird1 Posted October 30, 2019 Share Posted October 30, 2019 Reshape the Wall Polyline perhaps , but as Eric said easier to diagnose with the Plan available. M. Link to comment Share on other sites More sharing options...
jpdesign Posted October 30, 2019 Author Share Posted October 30, 2019 Plan file is too big to attached. Link to comment Share on other sites More sharing options...
GeneDavis Posted October 30, 2019 Share Posted October 30, 2019 Or use Dropbox. Many Chiefers use it for all their plan and layout files. Link to comment Share on other sites More sharing options...
jpdesign Posted October 30, 2019 Author Share Posted October 30, 2019 Make the plan file smaller. Now the file can be attached final_prosed_CA_forum.plan Link to comment Share on other sites More sharing options...
Kbird1 Posted October 30, 2019 Share Posted October 30, 2019 On 10/30/2019 at 3:25 PM, Kbird1 said: Reshape the Wall Polyline Expand Reshaping the Wall seems to work okay , delete the small triangular automatic wall with siding that generates on the right Link to comment Share on other sites More sharing options...
jpdesign Posted October 30, 2019 Author Share Posted October 30, 2019 Solver, Thank you so much. You are amazing. Could you help me on the other problem I have? I don't how to fix this glitch. The plan file is attached. Josh as-built.plan Link to comment Share on other sites More sharing options...
jpdesign Posted October 31, 2019 Author Share Posted October 31, 2019 Thank you solver. The problem is solved by changing the wall between garage and house to exterior and making it "lower wall type" to interior. Link to comment Share on other sites More sharing options...
