DianeP
TURN DECK PLANKING
I need the planking to go the at 90 degrees to its current orientation.  I have gone to the dialog for rooms and changed the plank direction from 0 to 90 degrees.  I have gone to the foundation page and changed the direction of the joists to run at 0 degrees instead of the 90 degrees it wants to run. It will change the joists but not the planks. Auto deck framing is on.  I remember being able to work this out before, but for some reason it escapes me now.  Help is greatly appreciated.
 image.thumb.png.27934983dde0e427e39da7fde6280ad6.png  image.thumb.png.7b459bd3e8ef973374c9ce9a7f87b63b.png
Did you force a rebuild after you changed the direction or just let it auto rebuild? Is keep deck framing after deleting checked?
56 minutes ago, solver said:
From
To
Thanks for your help, guys.  It got me thinking another direction.    I had changed the default, but it didn't change the planking on the deck that was already built.  I did get it to work by choosing the deck room on the plan and changing the plank direction on the deck to 90 degrees.  I guess the default change would have worked for a new deck, but not an existing deck.
On 10/23/2019 at 5:50 PM, DianeP said:
...I had changed the default, but it didn't change the planking on the deck that was already built...
Interesting situation.  I have also found that changing defaults does not affect already defined entities, but sometimes it does.  So, what are the principles behind affecting already defined objects when defaults are changed?
    28019
    Mableandpearl
    Mableandpearl
