How to produce a hi-res image of a floor plan?
M3taMorpHous3
Hi all ,
Is there a way to pump out / export / print a floor plan in high res?
I've been using the "export picture" function which produces low-res (50kb) thumbnail images but the quality is too low for the intended use (brochure).
The end-result needs to be a png (or similar) image file, preferably not a pdf.
Any tips would be appreciated.
Yes, PDF is the only way I know.
Send it to Layout on the largest paper possible then export to PDF at high DPI, open the resulting PDF and export as jpeg at "best" quality at least 300-400 pixels per inch.
This should be good for brochure printing. Make sure your image has enough extra canvas around the edges.
  • Upvote 2
