Pony Wall Corners Intersecting Non Pony Wall Corner
EconBlueprints
Hello,
I have this small ranch house with the Front 1st Floor Exterior Wall being a pony wall.  The upper part is horizontal siding over wood frame, the lower part is brick veneer over wood frme.
All other First Floor Exterior Walls are brick veneer over wood frame.
The upper portion of the front pony wall should be horizontal siding from side to side.  However the intersecting brick walls are showing at the corners.
How do you adjust the corners so the front upper portion is completely horizontal, while the lower portion is completely brick.
The plan is attached.  Elevation 1 notes the problem on the left side (note only on left side but applies to both sides.)
Thanks in advance,
Lane De Muro
99 Long Hill Plan.plan
