PvdPol Posted October 9, 2019 Share Posted October 9, 2019 Dear Members, I'm looking for a way to change my rope lighting according to the picture below. It is a alluminium profile of 42mm with a milky finish so that you actually don't see a lot of glow. I've been trying to achieve to same in chief architect x11 using the rope lighting. Where I've drawn the rope light '1mm underneath' the ceiling. I have issues achieving a look without the glow (attached image), which is i think logical since i did not carve it into the ceiling. I thought I would need some sort of milky finish, but this didn't give me the desired effect. (it is also not transparant). What would be the best method in achieving this? Thanks! Regards, Peter Link to comment Share on other sites More sharing options...
glennw Posted October 9, 2019 Share Posted October 9, 2019 I would try cranking up the Emissive property of the of the light's material. Link to comment Share on other sites More sharing options...
rlackore Posted October 9, 2019 Share Posted October 9, 2019 Like Glen said; maybe you don't need a light, just an object (Polyline Solid, Soffit, etc.) with an emissive material: Link to comment Share on other sites More sharing options...
PvdPol Posted October 9, 2019 Author Share Posted October 9, 2019 Thanks Folks! Much appreciated. This works I think. Have to fiddle some with the emissive but this looks like it works :). Link to comment Share on other sites More sharing options...
glennw Posted October 10, 2019 Share Posted October 10, 2019 One picture showed the light spilling down the wall - you will obviously need a light to get that effect. The other picture (without the light spilling down the wall) could be simulated with just a Molding Polyline with a high Emissive property. Link to comment Share on other sites More sharing options...
