MarkSM Posted August 29, 2019 Share Posted August 29, 2019 I’m looking for a new plotter/printer and the three that seem to be the “go to” are the -HP T130 and T530 -Canon iPF670 -Epson T3170 I do about half color and half black and white 24x36. I’ll need wireless connection, which I don’t think the Canon has. Wondering if any of you use my of these and what your experience is. Or any other one I’m missing under $2000. Thanks! Link to comment Share on other sites More sharing options...
Adam_Gibson Posted August 29, 2019 Share Posted August 29, 2019 I've been happy with the HP T120 for a year. Prior to that, I used an HP 110+ for over ten years. No issues, other than the occasional orneriness. Be sure to use OEM print heads. I assume the T130 is even better, and about $1k. I suggest the proprietary stand as well. Link to comment Share on other sites More sharing options...
parkwest Posted August 29, 2019 Share Posted August 29, 2019 I have the HP T520 and can't complain... before that I used an HP 450C. Before that I had an HP 1055CM but I didn't use it enough to justify the cost of replacing the large ink jugs all the time when they dried up. Before that I used an HP carousel pen plotter... that was fun to watch... you never knew where it was going to draw next on the paper. Link to comment Share on other sites More sharing options...
DougDM Posted July 4, 2020 Share Posted July 4, 2020 My HP 450c was working till I updated my Win 10 Pro computer, now I can’t get it to work. Been trying for 3days to no avail. So I’m looking (need to replace it) I was hoping to pick up an HP T520 but they’re no longer available, so I’ll probably go with the HP T530. Not a bad deal for $1,200. I usually just print con docs, occasionally a few pages in color. I did fine with the 450c so I’m sure the 530 will be as good. Can’t complain, the 450 lasted almost 20 years, but even with Win 10 before updating I was staring to have a few issues. So unless I hear bad things about the T530....time to pull the trigger. Link to comment Share on other sites More sharing options...
MoeGia Posted July 4, 2020 Share Posted July 4, 2020 5 hours ago, DougDM said: My HP 450c was working till I updated my Win 10 Pro computer, now I can’t get it to work. Been trying for 3days to no avail. So I’m looking (need to replace it) I was hoping to pick up an HP T520 but they’re no longer available, so I’ll probably go with the HP T530. Not a bad deal for $1,200. I usually just print con docs, occasionally a few pages in color. I did fine with the 450c so I’m sure the 530 will be as good. Can’t complain, the 450 lasted almost 20 years, but even with Win 10 before updating I was staring to have a few issues. So unless I hear bad things about the T530....time to pull the trigger. Please review this thread for a fix to the Windows update breaking the connection to your printer. Not sure if it's the same problem but it might help. Link to comment Share on other sites More sharing options...
DougDM Posted July 21, 2020 Share Posted July 21, 2020 Thank Moe. I'll try, even though I bought an HP T530...needed to get jobs done and printing couldn't wait. I haven't heaved the 450 just yet so I'll check out your suggestion. Link to comment Share on other sites More sharing options...
