john-ferguson Posted August 2, 2019 Share Posted August 2, 2019 the walls on the front and right sides of this building are the same. Yet i cannot get the end of the floor joists (which are now invisible) to be covered by any material. The room in that corner of the house is the same one on the front and on the right, both in the basement and ion the main floor. What am I missing here? Chief Premier X11 Link to comment Share on other sites More sharing options...
robdyck Posted August 2, 2019 Share Posted August 2, 2019 On 8/2/2019 at 10:19 PM, john-ferguson said: the walls on the front and right sides of this building are the same. Yet i cannot get the end of the floor joists (which are now invisible) to be covered by any material. The room in that corner of the house is the same one on the front and on the right, both in the basement and ion the main floor. What am I missing here? Chief Premier X11 Expand I had the same thing happen recently. The wall surface below my railing partially disappeared, quite randomly. Unfortunately I can't post this plan as it exceeds 200MB (and I don't have permission). I'll take a look at yours if you post it. I've had a couple of bugs that I've reported and Chief wasn't able to come up with a solution. This may be another bug. Link to comment Share on other sites More sharing options...
john-ferguson Posted August 7, 2019 Author Share Posted August 7, 2019 plan is attached MyZip.zip Link to comment Share on other sites More sharing options...
glennw Posted August 7, 2019 Share Posted August 7, 2019 Open the dbx for Bedroom #5 and uncheck Flat Ceiling Under This Room. I am not 100% sure why at this stage. I will poke it a bit more. Link to comment Share on other sites More sharing options...
john-ferguson Posted August 7, 2019 Author Share Posted August 7, 2019 Thanks, Glenn, that works (somehow) like a charm Link to comment Share on other sites More sharing options...
