Window Schedules
cjanderson66
Does anyone know how to force a Window number change to a window.  I have a window order from the supplier and the window numbers are not the same as my plan.  Let alone he decided to start off with a 00 window and not 01.  I would like to be able to manually give the window a number and it be reflected into the window schedule.  This would have been much easier if the window supplier would have started with #1 and I could have just moved that window up in the schedule.  Any thoughts....
You may need to abandon the Schedule Number system all together and use another editable column that is accessible through the window Components List.  Unfortunately this would also mean abandoning automatic call outs I think.
