Lighthouse Posted July 9, 2019 Share Posted July 9, 2019 I asked this years ago, but maybe there is now a way to do it. I've designed a roof with overhangs at the gable and rake. I want to create a tapered roof edge (angled soffit) so the roof gets thinner towards the outer edge of the overhang. I can create this tapered edge with a PS, or rafter tails, or a molding polyline, or a shadowboard on the gable end (soffit A in the attached drawing). But nothing seems to work on the rake edge (soffit B in the attached drawing). I would greatly appreciate any brilliant ideas. I have attached a simple test plan as well. Thanks!! soffit test.pdf soffit test.plan Link to comment Share on other sites More sharing options...
javatom Posted July 9, 2019 Share Posted July 9, 2019 Try using another roof plane for the soffit. Make it thin so it does not cut into the actual roof. The soffit would be the ceiling of the roof plane. Link to comment Share on other sites More sharing options...
Renerabbitt Posted July 9, 2019 Share Posted July 9, 2019 1 minute ago, javatom said: Try using another roof plane for the soffit. Make it thin so it does not cut into the actual roof. The soffit would be the ceiling of the roof plane. yup..give this man a +1 Link to comment Share on other sites More sharing options...
Lighthouse Posted July 9, 2019 Author Share Posted July 9, 2019 10 minutes ago, javatom said: Try using another roof plane for the soffit. Make it thin so it does not cut into the actual roof. The soffit would be the ceiling of the roof plane. shoot, I thought of that but rejected the idea for some reason. I'll give it a try, thanks Link to comment Share on other sites More sharing options...
Renerabbitt Posted July 9, 2019 Share Posted July 9, 2019 2 minutes ago, Lighthouse said: shoot, I thought of that but rejected the idea for some reason. I'll give it a try, thanks Just remember you will need to adjust the "baseline" angle at the inverse gable ("V") side of the soffit Link to comment Share on other sites More sharing options...
Lighthouse Posted July 9, 2019 Author Share Posted July 9, 2019 2 minutes ago, Renerabbitt said: Just remember you will need to adjust the "baseline" angle at the inverse gable ("V") side of the soffit Wait, now I see what the problem is. On soffit B, I want the slope to be perpendicular to the wall plan (starts low on the wall, ends high at the fascia (easier to see in the pdf). How do I make a roof plane that slopes in two directions- it has to slope to follow the roof, but also slope up towards the soffit Link to comment Share on other sites More sharing options...
Renerabbitt Posted July 9, 2019 Share Posted July 9, 2019 1 minute ago, Lighthouse said: Wait, now I see what the problem is. On soffit B, I want the slope to be perpendicular to the wall plan (starts low on the wall, ends high at the fascia (easier to see in the pdf). How do I make a roof plane that slopes in two directions- it has to slope to follow the roof, but also slope up towards the soffit as I mentioned, you will need to adjust the baseline angle to match the slope of your roof which is 15 degrees. then set your slope of the "soffit" roof plane to the degree you want, like -12 etc. Link to comment Share on other sites More sharing options...
Lighthouse Posted July 9, 2019 Author Share Posted July 9, 2019 2 minutes ago, Renerabbitt said: as I mentioned, you will need to adjust the baseline angle to match the slope of your roof which is 15 degrees. then set your slope of the "soffit" roof plane to the degree you want, like -12 etc. I get the idea, but don't know what direction to draw the roof. Can you do it on the attached plan and send it? I'm happy to pay for your time. I just want it to look like the picture. Once I see it on the plan I will understand what you did. Actually, unless you have X10 I won't be able to view it. Just to make sure we're on the same page, you are talking about Soffit B, right? Do I draw that roof parallel to the existing roof or perpendicular? Link to comment Share on other sites More sharing options...
Renerabbitt Posted July 9, 2019 Share Posted July 9, 2019 21 minutes ago, Lighthouse said: I get the idea, but don't know what direction to draw the roof. Can you do it on the attached plan and send it? I'm happy to pay for your time. I just want it to look like the picture. Once I see it on the plan I will understand what you did. Actually, unless you have X10 I won't be able to view it. Just to make sure we're on the same page, you are talking about Soffit B, right? Do I draw that roof parallel to the existing roof or perpendicular? this help? it's not perfect, I could've busted out my calculator..I'll leave you to that...but its damn close. the other plane is -15 baseline angle with a ridge height of 100 and slope of -12 as shown. Link to comment Share on other sites More sharing options...
Lighthouse Posted July 9, 2019 Author Share Posted July 9, 2019 16 minutes ago, Renerabbitt said: this help? it's not perfect, I could've busted out my calculator..I'll leave you to that...but its damn close. the other plane is -15 baseline angle with a ridge height of 100 and slope of -12 as shown thanks, sorry I'm so dense, but I still don't get it. Please see attached marked-up copy of your drawing with questions soffit test question.pdf Link to comment Share on other sites More sharing options...
Renerabbitt Posted July 9, 2019 Share Posted July 9, 2019 4 minutes ago, Lighthouse said: thanks, sorry I'm so dense, but I still don't get it. Please see attached marked-up copy of your drawing with questions soffit test question.pdf the DBX shown is for the plane highlighted in pink. here is the other plane: Link to comment Share on other sites More sharing options...
Lighthouse Posted July 9, 2019 Author Share Posted July 9, 2019 30 minutes ago, Renerabbitt said: the DBX shown is for the plane highlighted in pink. here is the other plane: ahhh, finally got it!! thanks!! I didn't realize that baseline angle is in the "z" direction, I thought it was "x" or "y". Link to comment Share on other sites More sharing options...
