SNestor Posted June 8, 2019 Share Posted June 8, 2019 I think I have an issue with my "template" plan as I cannot get walls located above invisible walls to build correctly. The wall in the attached plan is where the ceiling transitions from 12' tall to a room with a 9' tall ceiling. I attempted the same drawing in a stock Chief template plan and everything worked like it's supposed to...so, I gather I have a setting in my template plan that is goofy... Thanks! Plan attached: Gable End Wall Not Building Plan.plan Link to comment Share on other sites More sharing options...
glennw Posted June 8, 2019 Share Posted June 8, 2019 Steve, The wall is there, you just can't see it. Open your 3D view and Toggle on the "Walls, Invisible" in your Camera View Layer Set. Link to comment Share on other sites More sharing options...
SNestor Posted June 8, 2019 Author Share Posted June 8, 2019 7 hours ago, glennw said: Steve, The wall is there, you just can't see it. Open your 3D view and Toggle on the "Walls, Invisible" in your Camera View Layer Set. Wow...I guess I had a long day. Thank you Glenn for your help. Link to comment Share on other sites More sharing options...
StephenGreene Posted June 8, 2019 Share Posted June 8, 2019 I had this same problem the other day. Could not figure out what was going on. Thanks, Glenn. Link to comment Share on other sites More sharing options...
