junior Posted March 4, 2014 Share Posted March 4, 2014 Well, back again. Have my plot plan finished , but when I send it to layout I can't read the co-ordinates. How can I change the text size on the plot plan so it can be read on the layout? Link to comment Share on other sites More sharing options...
Gawdzira Posted March 4, 2014 Share Posted March 4, 2014 What you need to do is plan your drawings well. Your text size is set in your plan file. By knowing what scale you will send your file to layout determines your text size done in the plan file. For me, if I send a plan at 1/4" scale my text is 5". For 1/8" scale 10". For 1" details, 1.5". That puts all the text in layout at close to 1/8" tall actual. Link to comment Share on other sites More sharing options...
junior Posted March 4, 2014 Author Share Posted March 4, 2014 I did not explain my problem correctly. On my plot plan, when I open the polyline specification display, I select under Line Style the boxes that " Show Angle, Show Length, Show All Angles. It displays on the plot plan, but the print is so small I can't read it without zooming in to see the length and angle. This is the text size I want to increase. Link to comment Share on other sites More sharing options...
dshall Posted March 4, 2014 Share Posted March 4, 2014 I did not explain my problem correctly. On my plot plan, when I open the polyline specification display, I select under Line Style the boxes that " Show Angle, Show Length, Show All Angles. It displays on the plot plan, but the print is so small I can't read it without zooming in to see the length and angle. This is the text size I want to increase. Aha, an easy answer. The size of that text is controlled by the layer the box is on. If you want that box to have a different size text than any other box in your plan, put the box on it own unique layer and DEFINE THE TEXT SIZE FOR THAT LAYER in the LAYER DISPLAY OPTIONS DBX. Remember, the only thing that controls that text size is the layer that it is on. Can I get a star for that answer? By the way, good question, I do not think I realized the answer until you asked the question (I am always a few years behind everybody else). 2 Link to comment Share on other sites More sharing options...
junior Posted March 5, 2014 Author Share Posted March 5, 2014 Thanks again, It always easy when you know what your doing. For that you get a gold star. Link to comment Share on other sites More sharing options...
NCC-1701 Posted March 5, 2014 Share Posted March 5, 2014 Aha, an easy answer. The size of that text is controlled by the layer the box is on. If you want that box to have a different size text than any other box in your plan, put the box on it own unique layer and DEFINE THE TEXT SIZE FOR THAT LAYER in the LAYER DISPLAY OPTIONS DBX. Remember, the only thing that controls that text size is the layer that it is on. Can I get a star for that answer? By the way, good question, I do not think I realized the answer until you asked the question (I am always a few years behind everybody else). You got a 'star' from me. Thanks! 1 Link to comment Share on other sites More sharing options...
