andymcg Posted June 3, 2019 Share Posted June 3, 2019 Good morning, I was hoping someone could help me with some tips on how to place a sconce on cabinetry? I've tried creating a thin wall, but it's screwing up the cabinetry to either side of the unit. Link to comment Share on other sites More sharing options...
javatom Posted June 3, 2019 Share Posted June 3, 2019 Place it on the wall behind. Open the dbx for the light and adjust the "distance from wall to the depth of your cabinet. Link to comment Share on other sites More sharing options...
andymcg Posted June 3, 2019 Author Share Posted June 3, 2019 Thanks so much for the response; that worked! Link to comment Share on other sites More sharing options...
MarkMc Posted June 3, 2019 Share Posted June 3, 2019 3 hours ago, andymcg said: Good morning, I was hoping someone could help me with some tips on how to place a sconce on cabinetry? I've tried creating a thin wall, but it's screwing up the cabinetry to either side of the unit. If you simply place a recessed light too close to a cabinet you get a sconce on the cabinet. It's behavior I find annoying but will help with what you want. You can either change the default sconce ahead of time OR once it's placed use replace from library. They're easy enough to move around or up and down. Of course it won't adress what you need to do with wiring but some notes should take care of that. Link to comment Share on other sites More sharing options...
