CJSpud Posted May 23, 2019 Share Posted May 23, 2019 Is there a way to flip a plan 180° (swap ends ... not rotate) and do it for all levels in one move? Thanks. Link to comment Share on other sites More sharing options...
CJSpud Posted May 23, 2019 Author Share Posted May 23, 2019 I tried that and couldn't get the edit tool bar to show up so I could reflect about object. I will try it again to see if I can get it to work. Link to comment Share on other sites More sharing options...
CJSpud Posted May 23, 2019 Author Share Posted May 23, 2019 Thanks Eric ... I got it to work this time. Didn't something wrong the first time when doing the box around the plan. Link to comment Share on other sites More sharing options...
Ridge_Runner Posted May 23, 2019 Share Posted May 23, 2019 You may have had an item selected the 1st time that would not allow the selection to reflect or mirror. Link to comment Share on other sites More sharing options...
Ridge_Runner Posted May 23, 2019 Share Posted May 23, 2019 It will work with Edit Area like Eric said, but not if you just select everything visible with the standard selection arrow and then try to mirror - the option won't be available on the edit bar and transform/replicate has the "reflect" option grayed out. Link to comment Share on other sites More sharing options...
glennw Posted May 23, 2019 Share Posted May 23, 2019 Or...Reverse Plan Link to comment Share on other sites More sharing options...
CJSpud Posted May 24, 2019 Author Share Posted May 24, 2019 Glenn: That was what I was looking for ... although the other method worked OK. Not sure how I missed that but I did. Thanks. Link to comment Share on other sites More sharing options...
