UserKenW Posted May 17, 2019 Share Posted May 17, 2019 working in x9 I am having trouble with a polygon shaped deck with roof. One problem I have is when I highlight the deck on main level I have no handles to move the entire structure. What I am trying to do is have the polygon shaped deck sit over the corner of a separate rectangular shaped deck. Additional problems are: -if I put polygon in correct position initially the framing interferes with rectangular deck framing. -if I raise floor level of polygon deck only the walls and roof raise -Should I be able to rebuild floor framing after raising structure if anyone has attached a polygon deck to another deck especially sitting on step up I would love to exchange notes. Link to comment Share on other sites More sharing options...
Chopsaw Posted May 17, 2019 Share Posted May 17, 2019 You should be able to move the whole deck by selecting all of the walls. You may need to do some manual framing for a situation like that. There is a setting for "Automatically regenerate deck framing" on the Deck tab of the Room DBX Link to comment Share on other sites More sharing options...
DRAWZILLA Posted May 18, 2019 Share Posted May 18, 2019 That 2nd floor deck looks to me to be weak structurally , top heavy, you may want an engineer to look at that. Steel posts buried for lateral or steel shear walls beneath imbedded into some type of column. Just for f.y.i. Link to comment Share on other sites More sharing options...
