WildcatFury Posted May 8, 2019 Share Posted May 8, 2019 I have created a railing wall next to a ramp and then added a wall break to change the angle of the top of the wall to match the ramp slope. When I did this I lost the wall cap. Did I do this right and if so how do I retain or add back the wall cap? I am working in ver X10. Link to comment Share on other sites More sharing options...
WildcatFury Posted May 8, 2019 Author Share Posted May 8, 2019 Thanks Eric... I am fairly new to this software and learning as I go. I will try adding the stair but if I need to add the cap with the solid where is the best step by step for that. I tried creating the solid but could not get it to follow the angle/slope of the wall. I am sure it is something easy I am missing. Link to comment Share on other sites More sharing options...
ShaneK Posted May 8, 2019 Share Posted May 8, 2019 ramps Link to comment Share on other sites More sharing options...
WildcatFury Posted May 8, 2019 Author Share Posted May 8, 2019 Below is a couple of views of the sloped wall and ramp. All I want to do is match the wall cap of the wall at the landing (short wall to the right on the "sloped wall" view) to the sloped wall. When I sloped the top of the wall by adding edit corner angles is when the wall cap went away. Link to comment Share on other sites More sharing options...
WildcatFury Posted May 8, 2019 Author Share Posted May 8, 2019 Eric, I did what you suggested and went back and watched a video on creating polyline solid and figured it out. Thanks for your help. Link to comment Share on other sites More sharing options...
Michael_Gia Posted May 8, 2019 Share Posted May 8, 2019 You can draw a half wall and place a ceiling plane over it. That way you have precise placement of the height and slope. The ceiling plane will cut/crop your half wall. No adjusting little diamonds or drawing solids which won’t frame. Link to comment Share on other sites More sharing options...
