BFogarty Posted May 6, 2019 Share Posted May 6, 2019 Is it possible to get recessed lights without the "halo" around the outer ring? Just doesn't look realistic this way. Can't upload the plan at the moment, but will if necessary. Thx Link to comment Share on other sites More sharing options...
MarkMc Posted May 6, 2019 Share Posted May 6, 2019 Edit camera- turn off bloom. Do the same for camera defaults. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted May 6, 2019 Share Posted May 6, 2019 You can also turn down the lights as needed 1 Link to comment Share on other sites More sharing options...
BFogarty Posted May 7, 2019 Author Share Posted May 7, 2019 On 5/6/2019 at 1:49 PM, DRAWZILLA said: You can also turn down the lights as needed Just did this Perry, and it did help. I also added additional lighting in attempt to brighten things up....but it's still really dim. Any other thoughts on getting it brighter? Thanks! Link to comment Share on other sites More sharing options...
BFogarty Posted May 7, 2019 Author Share Posted May 7, 2019 On 5/6/2019 at 7:52 AM, MarkMc said: Edit camera- turn off bloom. Do the same for camera defaults. Done...Thanks! Link to comment Share on other sites More sharing options...
DRAWZILLA Posted May 7, 2019 Share Posted May 7, 2019 I use a lot of light sources , put them anywhere and they don't show in render view. It's like having extra lights without adding extra light fixtures. Make sure to change the amount of lights in the camera DBX to 50 or 100. also Link to comment Share on other sites More sharing options...
BFogarty Posted May 7, 2019 Author Share Posted May 7, 2019 5 minutes ago, DRAWZILLA said: I use a lot of light sources , put them anywhere and they don't show in render view. It's like having extra lights without adding extra light fixtures. Make sure to change the amount of lights in the camera DBX to 50 or 100. also Will give that a shot! Link to comment Share on other sites More sharing options...
MarkMc Posted May 8, 2019 Share Posted May 8, 2019 2 hours ago, BFogarty said: Any other thoughts on getting it brighter? Thanks! Technique options-for PBR adjust exposure and/or brightness; for standard render adjust ambient. 1 Link to comment Share on other sites More sharing options...
